I get too long byte length with the error message below: how do i solve it?
  • [Common 17-680] Path length exceeds 248-Byte maximum allowed by Windows: C:/Users/zaina/OneDrive/Skoleopgaver/Robotteknologi/Semester_4/Digital_Programmerbar_Elektronik/Lektion_3__Sekventiel_logik/Muxdisplay_version_2/Lsningsforslag_til_Muxdisplay_version_1/muxløsning_1.runs/synth_1/.Xil/Vivado-16168-DESKTOP-3ESB99P/realtime Please consider using the OS subst command to shorten the path length by mapping part of the path to a virtual drive letter. See Answer Record AR52787 for more information. Resolution: In Windows 7 or later, the mklink command can also be used to create a symbolic link and shorten the path.
Re: I get too long byte length with the error message below: how do i solve it?
Try moving your Xilinx folder directly into your C:/ drive; unfortunately Vivado for windows can't read filepaths that are too long.
But that only issue i get when i generate bitfile... I want the hardware only generate bitfile and not extra folders, how do i do it with the settings...
Hi @zaahm18 ,
You can try changing the location of bitstream file generation, check this below post might be helpful:
https://forums.xilinx.com/t5/Welcome-Join/How-do-I-change-the-location-of-the-bitstream-file-in-Vivado/td-p/737489
Raj
I used long path tool and I solve my error, unlock problem solution.
