ID_WIDTH does not match between ACP and axi_mem_intercon
in my design I would like to have 4 FFT engines working in parallel. I connect them to the PS through an AXI-DMA.
If I use up to 2 FFT blocks I can validate the design.
If I add the 3rd FFT block I receive the error
ERROR: [BD 41-237] Bus Interface property ID_WIDTH does not match between /processing_system7_0/S_AXI_ACP(3) and /axi_mem_intercon/m00_couplers/auto_pc/M_AXI(4)
I cannot see what I am doing wrong.
I attach the tcl to regenerate the the block design for the cases with 2 and 3 FFT.
Max
Re: ID_WIDTH does not match between ACP and axi_mem_intercon
See if these help:
http://www.xilinx.com/support/answers/56539.html
http://www.xilinx.com/support/answers/66114.html
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).
I don't really know what solved the problem, but I customized the interconnector manually several times with different options and at some point the error vanished
