Scholar beandigital
IDELAYCTRL clock
I am getting the following warning for a Zynq design. I have the IDELAYCTRL clock as a 200 MHz clock that comes from the Zynq clock generator. Is this not the correct thing to do? The design seems to work OK.
[DRC 23-20] Rule violation (PLIDC-14) IDELAYCTRL REFCLK should be same as ISERDES CLK - The BITSLICE cell IDELAYCTRL system_i/Interface_0/inst/U_idelayctrl REFCLK pin should be driven by the same clock net as the associated ISERDES system_i/Interface_0/inst/U_adc_if/genblk1[0].ISERDESE2_inst CLK or CLKDIV pin.
Re: IDELAYCTRL clock
Hi @beandigital
This message can be ignored if you are using 7 series or Zynq device.
This DRC is only applicable to Ultrascale devices.
The tool was incorrectly issuing this message for 7 series designs. This is already reported to factory and planned to be fixed in our next release 2016.3.
Deepika.
Hi @beandigital
Deepika.
@beandigital,
Check if the following AR#66013 helps.
http://www.xilinx.com/support/answers/66013.html
--Syed
