IP Core for Bus multiplexer
I m using ISE 10.1 and want to use a 16 bit width Bus multiplexer. Default IP cores which comes with Coregenerator has no Bus multiplexers. I went through the website and it says Bus multiplexer cores comes with default set up. I tried updating ISE using ISE 10.1 IP update. But installation fails.
Can anyone help me? I m very new to FPGA programming.
Historian
Historian
You're also pretty new to forums ...
I think you might be trying to run too soon.
Have you used ISE / Xilinx tools before ?
  If not I suggest you go through the ISE tutorilas on the xilinx web site.
What HDL are you intending to use ? yo might find that a bus mux does not need IP ,
