[IP_Flow 19-3461] Value 'reset' is out of the range for parameter 'RESET BOARD INTERFACE
This error message comes up after timing check :-
[IP_Flow 19-3461] Value 'reset' is out of the range for parameter 'RESET BOARD INTERFACE(RESET_BOARD_INTERFACE)' for BD Cell 'clk_wiz_1' . Valid values are - Custom
Does anybody know what it's trying to say ?
Cheers
Dave
Re: [IP_Flow 19-3461] Value 'reset' is out of the range for parameter 'RESET BOARD INTERFACE
hi @pomagadez ,
Is this IP core copied from some other location?
Anyway please refer https://www.xilinx.com/support/answers/66239.html.
Try to generate a new instance otherwise use add existing IP option.
Reshma
