[IP_Flow 19-851] Cannot find !H:/hdl-hdl_2018_r2/library/xilinx/common/up_xfer_cntrl_constr.xdc1! to reorder: "".
    I tried to run the ADV7511 reference design from https://wiki.analog.com/resources/fpga/xilinx/kc705/adv7511#dokuwiki__top) on ZedBoard, and I built the project myself in Vivado 2019.1.But when I souce axi_hdmi_tx,I  got the following error:
WARNING: [IP_Flow 19-1971] File named "../xilinx/common/up_xfer_cntrl_constr.xdc" already exists in file group "xilinx_anylanguagesynthesis", cannot add it again.
ERROR: [IP_Flow 19-851] Cannot find !H:/hdl-hdl_2018_r2/library/xilinx/common/up_xfer_cntrl_constr.xdc1! to reorder: "ERROR: [
ERROR: [Common 17-39] 'ipx::reorder_files' failed due to earlier errors.
while executing
"ipx::reorder_files -front $i_file $i_filegroup"
("foreach" body line 5)
invoked from within
"foreach i_file $ip_constr_files {
set i_module [file tail $i_file]
regsub {_constr\.xdc} $i_module {} i_module
ipx::add_file $i_file $i_fi..."
(procedure "adi_ip_properties_lite" line 31)
invoked from within
"adi_ip_properties_lite $ip_name"
(procedure "adi_ip_properties" line 3)
invoked from within
"adi_ip_properties axi_hdmi_tx"
(file "./axi_hdmi_tx_ip.tcl" line 31)
The github only have hdl-hdl_2019_r1,and I find it's for vivado 2018.3,so I have tried to modify these two files" adi_ip_xilinx.tcl ,adi_project_xilinx.tcl" to 2019.1.But I  got the same error .
ylh
Re: [IP_Flow 19-851] Cannot find !H:/hdl-hdl_2018_r2/library/xilinx/common/up_xfer_cntrl_constr.xdc1! to reorder: "".
HI @rshekhaw,
   I try to use  vivado 2018.3,and download "hdl-hdl_2019_r1" .Since there is no 2019_r1 NO-OS, and 2018_r2 seems to have some problems https://ez.analog.com/linux-device-drivers/f/q-a/109298/dmac_core-header-file-missing-for-adv5711-zedboard-reference-design/323493#323493.So I used the 2016_r2 NO-OS, but the display is always black.
ylh
