IP Interator referencing issue
ERROR: [filemgmt 56-190] Failed to uniquely resolve reference. Multiple different modules were found that match the name 'sync_pkt_rw_fifo_MxN'
Getting the above error in a block design where I have replicated a small block multiple times in a larger block design.
There is only one module named sync_pkt_rw_fifo_MxN, it is a verilog rtl module. It is instantiated multiple times in the original block design. There were no issues with build, synthesis, simulation of the original bd.
Vivado v2019.1 (64-bit) SW Build: 2552052 on Fri May 24 14:49:42 MDT 2019 IP Build: 2548770 on Fri May 24 18:01:18 MDT 2019
Re: IP Interator referencing issue
This issue is now resolved.
It appears that Vivado does not like having a verilog module instantiated within another verilog module AND instantiated as a separate instance in a bd. I resolved the issue by creating a separate veriliog module: module_name_bd.v. I used module_name.v when instantiating it withing another module and module_name_bd.v when instantiating it directly in the bd. A bit of a nuicance from a source management perspective but the errors went away...
If anyone disagrees that this is an issue with block designs in IP integrator please let me know.
P.
