IP Packager error [IP_Flow 19-3253] The Master AXIMM interface used as a read channel requires port maps ....
I get error message
IP Packager error [IP_Flow 19-3253] Bus Interface 'mstr' .The Master AXIMM interface used as a read channel requires port maps to interface signals ARADDR, ARVALID, ARREADY ..... Found missing port map(s) for : ARREADY
However these ports are already mapped.
Any clues ?
Thanks Simon
Re: IP Packager error [IP_Flow 19-3253] The Master AXIMM interface used as a read channel requires port maps ....
I have found solution to this error message. Without support from Xilinx moderators/tech support.
Error message: IP Packager error [IP_Flow 19-3253] Bus Interface 'mstr' .The Master AXIMM interface used as a read channel requires port maps to interface signals ARADDR, ARVALID, ARREADY ..... Found missing port map(s) for : ARREADY
The problem here is  can be identified by phrase  in error message:
"Found missing port map(s) for : ARREADY"
This means that the Bus interface formatting tool in Vivado  needs to find a port name containing the string  "ARREADY" or "arready" ( for the Bus format Master AXIMM)  . This port is missing so auto mapping cannot take place and the tool is confused. Check the RTL port map for the module in question and ensure the port is present so it can be mapped correctly.
Ignore rest of error message.
