IP Packager place C drivers in wrong directory
  IP Packager 2018.3.  I am packaging my own IP that has C drivers.
  Under "File Groups" --> "Software Drivers"  --> "driver_src"
  I right click on "driver_src" --> "Add Files".
  Then I added my custom  C drivers with "Copy sources into IP Directory"  But the C source files get copied into "IP_root_directory/src" instead of "IP_root_directory/drivers/IP_name_version/src".
  "drivers/IP_name_version/src" is the standard file structure for Xilinx IPs.  How can I force IP Packager to copy into this directory.
