IP-XACT files from IP Packager contains absolute file reference
I have an IP project under revision control.
when the component.xml file is generated  there is a xilinx tag of
 <xilinx:tag xilinx:name="Vendor:Library:Name:Version_ARCHIVE_LOCATION">C:/FPGA/[absolute path to project]</xilinx:tag>
Is there a reason why this cannot have a relative path? This prevents this project being portable between machines.
The tag is generated when ipx::save_core is run i think.
Edit: Vivado 2014.4 both Windows 7 and SLED11
Re: IP-XACT files from IP Packager contains absolute file reference
Do you see any errors when using the IP created on one machine on another machine?
Deepika.
Deepika.
I get a message that says top level ports cannot be found for the component
Can you post the complete error message please?
Do you see this error after creating the IP on new machine?
Are you able to create the IP on the old machine without errors?
Deepika.
Deepika.
INFO: [IP_Flow 19-1686] Generating 'Synthesis' target for IP 'ca_CPRI_Dual_Lane'...
ERROR: [IP_Flow 19-137] Could not find top-level ports for IP instance 'ca_CPRI_Dual_Lane'.
INFO: [IP_Flow 19-3500] Reset failed 'Synthesis' target for IP 'ca_CPRI_Dual_Lane'.
ERROR: [IP_Flow 19-3505] IP Generation error: Failed to generate IP 'ca_CPRI_Dual_Lane'. Failed to generate 'VHDL Synthesis Wrapper' outputs:
ERROR: [IP_Flow 19-98] Generation of the IP CORE failed.
If I repackage on the new machine the build runs fine
building on the original machine has no issues
It seems that when the IP revision goes up, the upgrade process in the outer project fixes this issue.
is there a way to tell vivado to upgrade IP even when the ip catalog revision is the same [like a refresh]
Referesh the IP repository and regenerate IP output products.
Deepika.
Deepika.
Refresh and regenerate has the same results
Which file is Vivado looking for when it says
