IP definition not found. IP contains locked subcore
I'm working with a design provided by another company, everything was working fine until today, I'm getting the attached error. What do I do?
@millersm6 you need to figure out where the ip was stored and it its repo back to the list of ip repos. Go to project settings | IP repositories and see if the ip location is there and if not add it.
