ivan_novelic
IP packager: Create customization parameters from generics
I am using Vivado 2018.3 to create and package IPs which contain ISERDES, IDELAY and ASYNC FIFO components.
I have instantiated them in component mode and each of them has a set of generics at their top level which I would like to propagate to the IP customization parameters table so that I can edit them from the IP customization GUI in the project which instantiates my custom IP (moreover, I have several IP instantiations where each needs to have different set of generics).
So, I can see the generic when I double click on the RTL component in the block design:
But I can not see it in the IP packager, nor connect the one I create in in the Customization Parameters tab to the existing generic in the block design:
Is there a manual how to do this?
Ivan
syedz
@ivan_novelic
Check topic "Customization Parameters" at page 54 in below user guide.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1118-vivado-creating-packaging-custom-ip.pdf#page=54
--Syed
syedz
@ivan_novelic
--Syed
