Visitor jesuabi.lc
IP packager crashes when removing TSTRB
Hi guys
I'm new with the IP packager, I was following the next tutorial to write a custom AXI Stream Slave
http://realisenow.sdu.dk/transfer-data-from-ps-to-pl-through-the-dma-simple-dma-with-custom-ip/
First of all, in my Vivado, the source codes are on Verilog not in VHDL ¿Is there any way to configure Vivado to write those files on VHDL by default again?
In second place, I'm having a problem when I'm trying to re-package the IP, Vivado just crashes.
The only thing I did on the source codes was delete the TSTRB port from the AXI Slave Port and add a digital output.
Not deleting the TSTRB from de Slave source code results on the next error
Coul someone explain to me what is causing the crashe and the error?
BR
Scholar brimdavis
Re: IP packager crashes when removing TSTRB
@jesuabi.lc   "when I'm trying to re-package the IP, Vivado just crashes. The only thing I did on the source codes was delete the TSTRB port from the AXI Slave Port"
The IP packager remains unstable and buggy when packaging code under development.
I think your particular remove-interface-port-and-repackage crash is a longstanding bug that can be solved by deleting TSTRB from the AXI interface before repackaging.
See the end of the following thread for more info:
   https://forums.xilinx.com/t5/Design-Entry/IP-Packager-crashes-when-merging-changes/td-p/728403
Make sure your project has "Target Language" set to VHDL  [ Project Manager => Settings => Project Settings => General => Target Language ]
-Brian
Scholar brimdavis
-Brian
Visitor jesuabi.lc
I got to generate the files on VHDL, thanks
But, I still got the crash when trying to repackage de IP
I first delete the TSTRB from the files and then repackage, but It doesn't work
EDIT
The option for remove the port isn't available on the menu
Scholar brimdavis
@jesuabi.lc   "The option for remove the port isn't available on the menu"
What version of Vivado are you using?
Here's a few things to try:
Plan A:
  • Right click the top level interface S00_AXIS in IP packager
  • Select "Edit Interface"
  • Select "Port Mapping" tab
  • Select TSTRB in the "mapped ports" window
  • Click the "-" button (top left of mapped ports window) to remove a port
Plan B:
If Plan A doesn't work, try removing the interface then re-inferring it:
  • Select "Remove Interface"
  • Right click in the "Ports and Interfaces" window and select "Auto Infer Interface"
  • Choose the correct interface type (e.g. axis_rtl ) and click OK
Plan C:
Exit Vivado, open the component.xml file in a text editor, and manually delete the TSTRB sections
(or you could similarly just delete component.xml from the packaged directory and re-package from scratch)
Also note, if the source edits to remove a port accidentally caused a syntax error, IP packager can act very strange...
-Brian
Visitor jesuabi.lc
I solved the problem this way:
-Right Clikc on the port
-Edit port
-Driver Value=0
-Accept
-This unlocks the "Remove Port" option on the Right Click menu on the Pots and Interface part
Thank you all for the help :D
BR
Jesus Abimael Lopez
