beandigital
IP repository path in vivado settings
I have a project that uses IP that I have created. In the settings I added the paths to the IP. But these paths are on my computer. I want to now craete a TCL script to generate the project. But when I do the paths are still pointing to my computer. I want to give this file to others to use.Is it possible to just add a path that is not absolute? Lets say I just have a dir with the main project and the IP in it. Can you just add a path that points to the dir without it being absolute? Thanks
rshekhaw
rshekhaw
