Visitor amer_c
IPCoreGen symbol is too large
    I use ISE 14.6. When I generate a FIFO symbol using IPCoreGen the resulting symbol is too large and cannot fit in the schematic though it has few pins.
  Any idea ?
Re: IPCoreGen symbol is too large
Check this article http://www.xilinx.com/support/answers/13615.htm
It has the details on how to increase the schematic page size or reduce the symbol size.
Hope it helps,
Deepika.
Deepika.
Visitor amer_c
Hello Deepika,
    Thanks for your message. I am aware of both suggessions, but that is not an option since increasing page size or reducing symbol size has its shortcomings :
* When updating the modified symbol all changes are lost.
* Printing becomes an issue when the paper size is increased (print too small).
 I have worked on several versions of Xilinx beginning from 9.2 and this was not an issue until 14.6. When a generated symbol was relatively larger than expected it could fit however (pre 14.6 versions). Obviously in 14.6 the problem is more evident and annoying.
AC
