Scholar ronnywebers
IPI - Create IP from a block design
I followed along hte tutorial in UG995 (2015.2), which results in a block design as in the attached screenshot.
Q: Is it possible to pack this entire block diagram into an IP block, so I can re-use it in other designs, to have a hierarchical design aproach in IPI. So the resulting IP block would have the ports : S00_AXI, ACLK, ARESTN, ext_spi_clk, iic_rtl, uart_rtl and spi_rtl.
Q: if so, how do I pack this? I tried to pack it as a project and pack it as a directory, but without real success. Is there an example on packing a BD
Re: IPI - Create IP from a block design
Hi @ronnywebers
Try the process mentioned in below article http://www.xilinx.com/support/answers/59355.html
Deepika.
Deepika.
To modify or add custom IP to the Vivado IP Catalog or IP Integrator, follow these steps:
(Custom IP is attached at the end of this answer record.)
  1. Open Vivado 2013.2, and select Manage IP > New IP Location.
  2. Click Next.
  3. Set the Part and IP Location from the Manage IP Settings dialog box, then click Finish.
  4. From the Tools menu, select the Package IP.
  5. Click Next.
  6. Point to the custom IP location and click Next.
  7. Click OK.
  8. As an example of modification, change the version from 1.0 to 1.1.
  9. You can modify the category in the IP Catalog that the custom IP can be found.
    For this example, it is changed from "BaseIP" to AXI Infrastructure.
  10. Click OK.
  11. Make sure that the IP compatibility matches with your project device. This is set to Virtex-7 by default.
  12. To add a Family, right-click and select Add Family...
  13. Click Package IP.
  14. You will now see the custom IP in the IP Catalog:
  15. Now, in the Vivado Project > select IP Settings:
  16. Select Add Repository and point to the IP repository, then click OK.
  17. You will now see the custom IP in the IP Catalog:
  18. This can also be seen in Add IP in IPI:
Thanks and Regards
Balkrishan
Scholar ronnywebers
Hello
is it my browser that behaves incorrect, but I can only see placeholdes for all the images in your latest answer - see attachment
