Scholar ronnywebers
IPI - How do I rename a block design (.bd file)
Is it possible to rename a block design once it's created? (i.e. rename design_1.bd to my_design.bd)
didn't find a way but to delete it and create it again.
Would it be possible to write the bd to a tcl script in a single command, then create a new bd with the desired name, and run the tcl script again to rebuild the bd contents? Guess the wrapper will also need to be deleted and regenerated
Or is there an easier way?
Scholar pratham
Re: IPI - How do I rename a block design (.bd file)
@ronnywebers BD name cannot be changed straightaway, Name property is Read only.
report_property [get_bd_designs ]
Property Type Read-only Visible Value
CLASS string true true diagram
COLOR string false true
FILE_NAME string true true base_zynq_design.bd
USE_IP_SHARED_DIR bool false true 1
Ony way would be write bd tcl using write_bd_tcl
This example creates a Tcl script from the current IP Integrator subsystem design, specifies a new name for the block diagram, specifies that IP versions should not be included, and also indicates a folder to write the block diagram to when it is created by running the output bd_tcl script:
write_bd_tcl -bd_name newMB1 -no_ip_version -bd_folder C:/Block_Designs projMB1
-Pratham
Scholar pratham
-Pratham
