Participant hananz
IPI error in GT ip blocks
System:
win 10, vivado 2018.2
I get an error in a new project (selected ZCU106 board), created a block design and selected aurora 64b/66b (also happened with aurora 8b/10b).
this is the error:
startgroup
create_bd_cell -type ip -vlnv xilinx.com:ip:aurora_64b66b:11.2 aurora_64b66b_0
ERROR: [Common 17-69] Command failed: Invalid site name 'GTHE4_CHANNEL_X0Y0' specified for location
ERROR: [IP_Flow 19-3477] Update of parameter 'MODELPARAM_VALUE.C_REFCLK_LOC_P' failed for IP 'design_1_aurora_64b66b_0_1'. ERROR: [Common 17-69] Command failed: Invalid site name 'GTHE4_CHANNEL_X0Y0' specified for location
ERROR: [IP_Flow 19-3428] Failed to create Customization object design_1_aurora_64b66b_0_1
CRITICAL WARNING: [IP_Flow 19-973] Failed to create IP instance 'design_1_aurora_64b66b_0_1'. Error during customization.
ERROR: [BD 41-1712] Create IP failed with errors
ERROR: [BD 5-7] Error: running create_bd_cell  -vlnv xilinx.com:ip:aurora_64b66b:11.2 -type ip -name aurora_64b66b_0 .
ERROR: [Common 17-39] 'create_bd_cell' failed due to earlier errors.
endgroup
If I try to add an axi fifo block it was successful.
someone else reported a similar error but received no answer https://forums.xilinx.com/t5/Design-Entry/IP-Failed-to-create-IBERT-IP-in-Vivado-2017-4/td-p/933467
can you advise ?
Thank you,
hanan
Participant hananz
Re: IPI error in GT ip blocks
Probably the reason for this problem is something in win10 update
win10 version 1809 build 17763.253 = Error
win10 version 1803 build 17134.556 = No Errors
Participant hananz
here some more info....
It seem that when an ip is using a GT I get an error, on an existing project I tried to change a parameter in "dma/bridge subsystem for pci express" and I receive the following error:
startgroup
set_property -dict [list CONFIG.pf0_interrupt_pin {NONE}] [get_bd_cells xdma_0]
INFO: [Device 21-403] Loading part xczu7ev-ffvc1156-2-e
ERROR: [Common 17-69] Command failed: Invalid site name 'GTHE4_CHANNEL_X0Y18' specified for location
ERROR: [IP_Flow 19-3329] update_GT_CHAN_SITES of meta parameter GT_CHAN_SITES failed. Unknown channel site 'GTHE4_CHANNEL_X0Y18'
ERROR: [IP_Flow 19-3329] update_GUI_GT_QUAD_INFO of meta parameter GUI_GT_QUAD_INFO failed. Unknown channel site 'GTHE4_CHANNEL_X0Y18'
ERROR: [IP_Flow 19-3332] Tcl error in configuring meta parameters procedures.
ERROR: [IP_Flow 19-3428] Failed to create Customization object zynq_bd_xdma_0_0/zynq_bd_xdma_0_0_pcie4_ip/zynq_bd_xdma_0_0_pcie4_ip_gt
CRITICAL WARNING: [IP_Flow 19-973] Failed to create IP instance 'zynq_bd_xdma_0_0_pcie4_ip_gt'. Error during customization.
ERROR: [Common 17-70] Application Exception: Failed to create subcore IP 'zynq_bd_xdma_0_0_pcie4_ip_gt'. Create IP failed with errors
CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file 'c:/Xilinx/Vivado/2018.2/data/ip/xilinx/pcie4_uscale_plus_v1_3/elaborate/gtwizard_elaborate_uscale_plus_v1_3.xit': ERROR: [Common 17-70] Application Exception: Failed to create subcore IP 'zynq_bd_xdma_0_0_pcie4_ip_gt'. Create IP failed with errors
ERROR: [IP_Flow 19-167] Failed to deliver one or more file(s).
ERROR: [IP_Flow 19-3541] IP Elaboration error: Failed to generate IP 'zynq_bd_xdma_0_0/zynq_bd_xdma_0_0_pcie4_ip'. Failed to generate 'Elaborate Sub-Cores' outputs:
ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file 'c:/Xilinx/Vivado/2018.2/data/ip/xilinx/xdma_v4_1/subcore/pcie_core_elaborate.xit': ERROR: [Common 17-39] 'set_property' failed due to earlier errors.
ERROR: [IP_Flow 19-3541] IP Elaboration error: Failed to generate IP 'xdma_0'. Failed to generate 'Elaborate Sub-Cores' outputs:
ERROR: [Common 17-70] Application Exception: Failed to create subcore IP 'zynq_bd_xdma_0_0_pcie4_ip'. IP name 'zynq_bd_xdma_0_0_pcie4_ip' is already in use in this project.  Please choose a different name.
CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file 'c:/Xilinx/Vivado/2018.2/data/ip/xilinx/xdma_v4_1/subcore/pcie_core_elaborate.xit': ERROR: [Common 17-70] Application Exception: Failed to create subcore IP 'zynq_bd_xdma_0_0_pcie4_ip'. IP name 'zynq_bd_xdma_0_0_pcie4_ip' is already in use in this project.  Please choose a different name.
ERROR: [Common 17-70] Application Exception: Failed to create subcore IP 'xdma_v4_1_1_blk_mem_64_reg_be'. IP name 'xdma_v4_1_1_blk_mem_64_reg_be' is already in use in this project.  Please choose a different name.
CRITICAL WARNING: [IP_Flow 19-1747] Failed to deliver file 'c:/Xilinx/Vivado/2018.2/data/ip/xilinx/xdma_v4_1/subcore/blk_mem_gen_elaborate.xit': ERROR: [Common 17-70] Application Exception: Failed to create subcore IP 'xdma_v4_1_1_blk_mem_64_reg_be'. IP name 'xdma_v4_1_1_blk_mem_64_reg_be' is already in use in this project.  Please choose a different name.
INFO: [IP_Flow 19-3438] Customization errors found on 'xdma_0'. Restoring to previous valid configuration.
ERROR: [IP_Flow 19-3439] Failed to restore IP 'xdma_0' customization to its previous valid configuration.
ERROR: [BD 41-245] set_property error - Customization errors found on 'xdma_0'. Restoring to previous valid configuration.
INFO: [Common 17-17] undo 'set_property -dict [list CONFIG.pf0_interrupt_pin {NONE}] [get_bd_cells xdma_0]'
endgroup
This project work just fine a few weeks ago.
when I try to add "axi_fifo" there is no error.
Hanan
Participant hananz
error occurred also:
1. 2018.3
2. similar PC - same HW, WIN10 (not duplicated by image)
Participant hananz
