Scholar ronnywebers
IPI - is there any difference between 'create interface port' and 'make external'
in IPI, if I right click on a port of an IP block, for example the S00_AXI port of an interconnect, in the drop down menu one can choose between :
- make external
- create interface port
Q: is there any difference between both?
Re: IPI - is there any difference between 'create interface port' and 'make external'
They should behave the same way. Create Interface Port allows you examine name/vlnv before creation.
You can also select many pins and do Make External.
Krishnan
Krishnan
check this tutorial you will get detail step
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_2/ug995-vivado-ip-subsystems-tutorial.pdf
Thanks and Regards
Balkrishan
