Newbie wd5gnr
ISE 13.1 Webpack Lin64 Coregen terminate called after throwing an instance of 'Port_ThrException::Exception
Trying out 13.1. When I try to make a block or distributed memory I get the above message when it is done (and before it adds the file to the project). I tried adding the files manually and I get odd error messages that I'm sure are due to the incomplete run.
Searching for Port_ThrException showed up nothing anywhere that I can find. Any help?
Oh. By the way, hitting browse for a COE file also crashes the Core Generator.
Re: ISE 13.1 Webpack Lin64 Coregen terminate called after throwing an instance of 'Port_ThrException::Exception
this sounds like something is wrong with your installation OR you're running on an unsupported Linux.  Which Linux are you on?
this space intentionally left blank
