appubaje
ISE 13.4 ERROR:coreutil:1010
Hi , I've recently migrated to 13.4 from 12.4 and I'm using fedora 15.When I try to generate MAC core i get  error:coreutil:1010 error with
1)returning a non-zero exit code '2'
2)./../netgen: application received signal 11.
3)error:sim Error found during generation.
4)error:sim - Failed to generate 'MAC' . An error encountered during generation.Please see the log for details.
5)Error:sim:877 - Error found during execution of IP 'Ten Gigabit Ethernet MAC v10.'
Have you faced any similar issues ?
Thank you
howardp
Is this the only error that you see.
I searched through our case logs and found three cases with this error but all were preceeded by another error first.
I also did a google search and found several hits (many from Xilinx users).  Most of the hits suggested a relation a kernal upgrade.
If you want to get a more complete coregen log run coregen with debug mode and java verbose messaging turned on (coregen -ddd -J verbose).
eastzone
I have the same problem. It seems related to netgen on Fedora 15 (14 is fine). The good.ngc contains the 10G MAC netlist generated on another machine. I tried both 13.2 and 13.3 and they behaves the same. I haven't tried 13.4 though.
My machine
[XXX@XXX small]$ uname -a
Linux XXX 2.6.42.3-2.fc15.x86_64 #1 SMP Thu Feb 9 01:42:06 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
[XXX@XXX small]$ netgen -w -ofmt verilog good.ngc
Release 13.3 - netgen O.76xd (lin64)
Copyright (c) 1995-2011 Xilinx, Inc. All rights reserved.
Command Line: netgen -w -ofmt verilog good.ngc
Reading design 'good.ngc' ...
Flattening design ...
Processing design ...
Preping design's networks ...
Preping design's macros ...
Writing Verilog netlist file 'good.v' ...
INFO:NetListWriters:633 - The generated Verilog netlist contains Xilinx UNISIM
simulation primitives and has to be used with UNISIM simulation library for
correct compilation and simulation.
Number of warnings: 0
Number of info messages: 1
Total memory usage is 328080 kilobytes
Created netgen log file 'good.nlf'.
Segmentation fault (core dumped)
When doing a dmesg
[XXX@XXX small]$ dmesg | tail -n 4
[ 4957.178926] netgen[2848]: segfault at 0 ip 00007f030ae7a80f sp 00007fff7322fa00 error 4 in libxalanc.so[7f030ab8d000+40e000]
[ 5782.916444] netgen[2927]: segfault at 18 ip 00007f08edd04812 sp 00007fff948d21b0 error 4 in libxalanc.so[7f08eda17000+40e000]
[ 5825.965135] netgen[2935]: segfault at 18 ip 00007fc3b0453812 sp 00007fff5d07dbe0 error 4 in libxalanc.so[7fc3b0166000+40e000]
[ 6051.180474] netgen[2950]: segfault at 0 ip 00007f42e0ca780f sp 00007fffd3af53d0 error 4 in libxalanc.so[7f42e09ba000+40e000]
eastzone
My machine
When doing a dmesg
Update:
This problem seems related to
http://www.xilinx.com/support/answers/43865.htm
http://forums.xilinx.com/t5/EDK-and-Platform-Studio/Core-dump/td-p/144456
When adding LD_PRELOAD=/tools/xilinx/13.1/ISE_DS/ISE/lib/lin64/libXst2_Core.so to netgen, it stops crashing. However, it doesn't work when add that with coregen since netgen is a subprocess. When doing a "dmesg" I can still see the same netgen crashes.
Fedora 15 uses glibc 2.14, while Fedora 14 uses glibc 2.13. So this can be the source of difference.
ericmo
I've been having the same problem in my Ubuntu.
All I've tried to is to add an Tri-Mode Ethernet MAC Core source to my (empty) project.
It returns:
Generating VHDL structural model.
ERROR:coreutil:1010 - Command '/opt/Xilinx/13.4/ISE_DS/ISE/bin/lin/netgen
   -intstyle ise -w -sim -ofmt vhdl "./tmp/_cg/ethx.ngc" "./tmp/_cg/ethx.vhd"'
   failed, returning a non-zero exit code '2':
   /opt/Xilinx/13.4/ISE_DS/ISE/bin/lin/netgen: application received signal 6.
ERROR:sim - Error found during generation.
ERROR:sim - Failed to generate 'ethx'.  An error encountered during generation.
Wrote CGP file for project 'ethx'.
I've searched for a glibc package in my system, but I haven't found one.
Then I've tried to apt-get install glibc and haven't found a package in the Ubuntu repo.
Should I download the package from GNU C page (I'd rather not)?
Did installing the previous version of this library solve the problem for you?
