Instructor
Instructor
ISE 14.6 Clocking Wizard 3.6 silliness
Running the Clocking Wizard (v3.6) from within ISE 14.6, there is some silliness in the Clocking Wizard.
Selections:
  • Frequency synthesis
  • Phase alignment (doesn't matter)
  • Minimise power (doesn't matter)
  • PLL_Base (Spartan-6)
  • Differential input clock capable pin (doesn't matter)
                                  ---------Wizard reported----------
input clock   requested output    "actual"     VCO         input
frequency     clock frequency     clock freq   frequency   frequency
100M            900M               900M         900M        100M
200M            900M               900M         900M        200M
300M            900M               900.090M     900.090M    300.030M
400M            900M               900M         900M        400M
450M            900M               900.090M     900.090M    450.045M
Searched for bugs and fixes on the main website, as well as the forums, and did not find anything which describes this problem.  Of course, i may not have searched in the right places with the right search terms...
-- Bob Elkind
SIGNATURE:
Summary:
Re: ISE 14.6 Clocking Wizard 3.6 silliness
Hi Bob,
Thanks for bringing this in to our notice.
I have found a similar description in internal CR 677921.
From the CR, it looks like this issue is fixed in V5.1 version of core (vivado 2013.3 or vivado 2013.4).
I have tested this and below are the screenshots from ISE 14.6 and Vivado 2013.4
From ISE:
From vivado:
Can you check this in V5.1 version of core at your end?
Deepika.
Deepika.
Instructor
Instructor
Deepika, you should understand that using Vivado is a useful suggestion only for those folks who are targeting device families which are not supported by ISE.  From your answer, it seems that bug fix support for ISE effectively slowed down or halted sometime in early 2013.  The folks who wrote and responded to internal CR 677921 either did not check with the ISE version, or did not bother to fix the ISE version.
As a user, there is a sense that many who work at Xilinx believe that the answer to any or all ISE problems is to migrate to Vivado.  This belief cannot be more wrong, as ISE and Vivado serve different and (mostly) separate product lines.  To repeat:  ISE and Vivado are not interchangeable.
In the FPGA marketplace, Xilinx has effectively split into two companies with two different sets of product lines, two different development workflows, and two different support levels.
It would be helpful to the Xilinx user community if Xilinx issued a policy statement describing what software support, if any, to expect for ISE, going forward.  There is no point in bothering with bug reports for ISE if they will be ignored, except to provide a warning for other users.
-- Bob Elkind
SIGNATURE:
Summary:
