10-28-2020 12:29 PM - edited 11-03-2020 01:45 PM
I have installed Xilinx 14.7 on RHEL 6. When I attempt to execute the the ise application I see the splash screen followed by a segmentation fault. I have tried resolving this issue using various recommendations on the internet but I cannot overcome this issue.
Please let me know if I need to provide additional information.
Thank you,
Ryan
11-03-2020 01:44 PM
Hello watan,
Thank you for your assistance. The version of RedHat is 6.10.
I ran the programs that were seg faulting in gdb and discovered that the seg fault was happening at libSecurity_FNP.so. I was able to resolve the issue by replacing libSecurity_FNP.so with libSecurity.so. I copied libSecurity_FNP.so to libSecurity_FNP.so-orig and create a symbolic link to map libSecurity_FNP.to libSecurity.so.
10-29-2020 10:45 AM
Hi @ryan7
Could you share what error messages you are seeing and what solutions you have already tried?
There is an SR that handles Segmentation Fault due to memory usage. Did you try this method?
https://www.xilinx.com/support/answers/64434.html
10-29-2020 03:03 PM - edited 10-29-2020 03:03 PM
Hi @ryan7
Would you inform your detail version (revision) of RHEL, too ? (ex. RHEL 6.10 and so on)
11-03-2020 01:41 PM
Hello philipwu,
Thank you for your response. The error I was receiving was a segmentation fault with no other error message present. I have a solution and will make another post with the solution.
11-03-2020 01:44 PM
Hello watan,
