ISE 14.7 - strange behviour. Files missing in design view
Hi guys,
I'm using ISE 14.7 and today my .v files have disappeared from my workspace design windows, but they are still in the files windows.
How can I fix that error? I have closed ISE and opened it again but the error is still there.
I show you that:
no files here
files here
Re: ISE 14.7 - strange behviour. Files missing in design view
Hi @kardec,
You can check the files panel 'view association' column which should show the design view to which the module is associated. So for example, your tb should be visible in simulation.
Prathik
Please mark the appropriate post as an answer "Accept as solution" in case it helps to resolve your query.
hahaha, that is not a solution!
The files are missing from the design view window. I need them there in order to run synthesis, and other operations ...
Can you tell me how can I fix that error? It's an error in your software.
Thanks!
Can anyone please tell me how to solve this problem?
It is causing many problems in my company.
Thanks in advance
Maybe, but laughing at somebody who offers a suggestion will discourage other posters.
In my experience, if an ISE project file is corrupted, the easiest solution is to start a new project.  You still have all of your source and coregen files.  Copy to a new folder and start a new project and add your files.
Hello @kardec,
This topic is still open and is waiting for you.
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hi @kardec
Hey, what type of files are missing and can you attach one here as an example? Then we should also be able to reproduce the problem in that case.
Did you try bruce's suggestions? Did you check view associations to see where it is associated?
Prathik
I tried that; I created a new project but the problem is still there ... the same files are missing.
Please find attached the file which is always missing.
any help on this?
Now IP cores are disappearing ... however, the synthesis can be done.
@kardec
I am unable to understand the problem. Your screenshot shows conv_3 in files view.
Just add this file in new project and check.
Prathik
The problem is: My project has several files and they disappear from the design view.
Sometimes one file disappear, other times, another different files disappear.
Today, one IP core generated with Core Generator disappeared. That core was there in my computer, but it does not appear in the design view. Other times, the top module disappears, so I cannot make the synthesis ...
Do you understand this? I have removed and installed again ISE... but the problem is still there. I have created a new project ...but the problem is still there.
I cannot work in this situation, I'm losing a lot of time.
Hi @kardec,
1.  Which OS are you using for ISE 14.7?
2.  Try with an example design and check you face the same issues or not.
3.  Do you see any error messages in message box?
hemangd
hemangd
@kardec,
>>[The problem is: My project has several files and they disappear from the design view.]
In addition to above queries from hemangd, please attach your archived project for us to test. I can send you FTP link if needed for the same.
Also, please attach a screenshot of complete files panel (check my initial reply) once you load the project first in ISE.
Prathik
