ISE automating a build
I have used the ISE GUI to build until now but ideally want to automate from a batch file.
I have saved a TCL file from ISE. Is there a way of running the build from a batch file (IE start ISE and automatically run the tcl script).
Andy
Re: ISE automating a build
Yes,  please refer below relavant links
http://www.doulos.com/knowhow/tcltk/xilinx/
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/devref.pdf
https://groups.google.com/forum/#!topic/comp.arch.fpga/jwqzydznXVw
Hope it helps and give you a good start.
Vanitha
