Visitor awetman
ISE control in command line
I want to build a script file to control the workflow:
(1)synthsis:
its command is "xst -ifn <script file>"
in <script file>,we can write: run -ifn <module file> -ifmt mixed -ofn <XXX.ncg> -ofmt NCG -p xc3s200-5-ft256 -top topmodule
and get the synthesis result
(2)ngdbuild
(3)map
(4)par
(5)trce
(6)bitgen :get the final bit file which can be downloaded into FPGA board.
Questions:
#1 Is there a command for downloading the bit file into FPGA board?
#2 Can ISE recognize Diligent JTAT-USB cable?I use Diligent's tool- ExPort,and it can download the bit file into FPGA.Why iMPACT cannot ,and just reports the following error?
Waring:iMPACT:923- Can not find cable,check cable setup!
Re: ISE control in command line
1) Yes. Normally (the case outlined in #2) you would use iMPACT. Though most people use the GUI, it is available in batch mode too:
http://toolbox.xilinx.com/docsan/xilinx8/help/iseguide/mergedProjects/impact/html/imp_examples.htm
http://toolbox.xilinx.com/docsan/xilinx9/help/iseguide/mergedProjects/plugin_imp/html/pim_categorical_listing_batch_mode_commands.htm
http://toolbox.xilinx.com/docsan/xilinx92/help/iseguide/mergedProjects/plugin_imp/html/pim_categorical_listing_batch_mode_commands.htm
2) I believe iMPACT, Chipscope, and XMD only recognize Xilinx cables (e.g. Parallel-IV, Platform USB Cable (and embedded equivalents on S3E Starter Kit and S3A/AN Starter Kit), Platform USB Cable II, etc.
As far as I know, there is no standard software interface to the cables so other manufacturers have their own drivers and download applications.
If you want to work with these application, using a Xilinx cable is likely the path of least resistance.
http://www.xilinx.com/onlinestore/program_solutions.htm#pc
bt
