assaf123
ISE doesnt support dual core?
I have ise 12.4 isntalled on my e5400 computer (duall core), and i dont have an -MP switch when i enter process properties (for example, implemetation process)
what can be done?
ywu
Looks like the multi-threading is not available for all device families. My snapshot was from a Virtex6 design. Just checked when I changed the target device to a Spartan3E, the multi-threading option is not there on the Map Properties.
Cheers,
Jim
bassman59
Historian
Historian
@assaf123 wrote:
what can be done?
Demand that Xilinx finally do multi-processor versions of their tools.
eteam00
Instructor
Instructor
Great idea.  What other things should we demand?
- Bob Elkind
SIGNATURE:
Summary:
ywu
It's already in the tool under multithreading (see the snapshot below). The actual speed-up varies for different designs.
Cheers,
Jim
assaf123
Jim,
This is exactly what i was talking abput - i dont have this switch (-mt) although i DO HAVE a multi processor computer E5400.. my college has the same computer, the same version of ise and he DOES have this switch... i am really confused?
eteam00
Instructor
Instructor
This is exactly what i was talking about - i dont have this switch (-mt) although i DO HAVE a multi processor computer E5400.. my college has the same computer, the same version of ise and he DOES have this switch... i am really confused?
Most of the Xilinx apps folks are sleeping - it's the dead of night.  So I'll try an answer :)
I'm running ISE 12.4 on a Vista x64 machine with 8GB of DRAM.  Both 32bit and 64bit ISE Navigator show the MAP process multi-thread switch.
The OS and the DRAM complement might have something to do with enabling or disabling the MAP multi-thread switch.  By the way, you won't see this switch unless you have selected/highlighted the MAP process in the PROCESSES pane, then select in the command toolbar Process > Process Properties.
- Bob Elkind
SIGNATURE:
Summary:
ywu
Assuming you're on the Map Properties window, right above the "OK"/"Cancel" buttons, there is a dropdown list called "Property Display Level". Change it to "Advanced" and you will see the Multi-threading option.
@assaf123 wrote:
Jim,
Cheers,
Jim
assaf123
Hi guys...
I am getting similiar window as the screenshot that Jim displayed, but WIHTOUT the -mp switch, and i AM clicking on the advanced , as you can see
So what can be done?
ywu
Cheers,
Jim
assaf123
Oh,
thats explains everything.. my desing is of spartan3adsp and my college is of virtex -5
very strange whough, why it is not supported for all devices
Thank you all
eteam00
Instructor
Instructor
thats explains everything.. my desing is of spartan3adsp and my college is of virtex -5 very strange whough, why it is not supported for all devices
Just a guess on my part....
ISE navigator is a 'shell', and behind the shell are completely different SW modules for MAP:
  • older code for Spartan 3x place/route, which pre-dates 'multi-thread' design ("don't fix it if it isn't broken")
  • newer code for Virtex 5/6 and Spartan 6 place/route, designed with 'multi-thread' from the start
- Bob Elkind
SIGNATURE:
Summary:
assaf123
Sounds logical... wht bother make a new code for old devices..
