uyeshiro
Identification step problem whjile packaging IP in Vivado
Hello.
I tried to package a VHDL file to put in a user IP library to use in a larger project.  I get a warning while in the Identification packaging step: [IP_Flow 19-1652] Component 'IFA:vivado_ip:fpga_misc:0.1(fpga_misc)': The IP is hidden from the catalog GUI and there should be no taxonomies entered.
I have no idea what this means, and a search for IP_Flow 19-1652 doesn't bring up anything helpful.
The fields in the Identification tab are filled out as:
Vendor:  IFA
Library:   vivado_ip  <this is a directory under c: where another ip exists and is used>
Version:  0.1
Display Name: fpga_misc
Description: Misc logic
Vendor display name: IFA
Company url; <blank>
Categories: /Embedded_Processing/Utility
Root directory:  c:/vivado_ip/fpga_misc
Xml file name:   c:/vivado_ip/fpga_misc/component.xml
Any help would be much appreciated.
swolf
When using the wizard steps to first package the IP, I would guess you chose "package directory" and then checked "package as library core".
A library core is simply a collection of hdl files that can be shared among other IP.  In this case, these "libraries" are not directly instantiated in a block diagram (as a collection of files, there would typically be many top level modules).  They are not shown in the catalog.  Since the IP is not shown in the catalog, there is no need for a taxonomy ("categories").  Please leave the categories blank in this case.
swolf
uyeshiro
Thanks.  That worked.
