Anonymous
Not applicable
Illegal redeclaration???
This is my codes
`timescale 1ns / 1ps
`define Digit 20
`define PACK_ARRAY(PK_WIDTH,PK_LEN,In,Out)  genvar pk_idx; generate for(pk_idx=0; pk_idx<(PK_LEN); pk_idx=pk_idx+1) begin:PACK assign Out[pk_idx][((PK_WIDTH)-1):0]=In[((PK_WIDTH)*pk_idx+((PK_WIDTH)-1)):((PK_WIDTH)*pk_idx)]; end endgenerate
module Prefix_carrytree(Ain,Gin,Cin,Cout,C    );
input  [79:0] Ain  ;
input  [79:0] Gin;
input Cin;
output reg Cout;
output reg [79:0]C;
wire [3:0] A[20:0];
wire [3:0] G[20:0];
`PACK_ARRAY(4,20,Ain,A)
`PACK_ARRAY(4,20,Gin,G)
To make it simple, I am try to pack a vector [79:0] into an array of 4*20.
However, when I call the second PACK_ARRAY, it says the pk_idx is illegal redeclaraed. Can anyone help me about it???
Professor
Professor
Re: Illegal redeclaration???
A genvar is local to a generate loop and can be re-used.  However the proper syntax places the
genvar declaration inside the loop like:
`define PACK_ARRAY(PK_WIDTH,PK_LEN,In,Out) \
  generate \
    genvar pk_idx; \
    for(pk_idx=0; pk_idx<(PK_LEN); pk_idx=pk_idx+1) \
      begin:PACK assign \
        Out[pk_idx][((PK_WIDTH)-1):0]=In[((PK_WIDTH)*pk_idx+((PK_WIDTH)-1)):((PK_WIDTH)*pk_idx)]; \
      end \
endgenerate
You can also use several lines to make your macro definition more readable as shown above.
From the Verilog LRM:
"The macro text can be any arbitrary text specified on the same line as the text macro name. If more than one
line is necessary to specify the text, the newline shall be preceded by a backslash (\). The first newline not
preceded by a backslash shall end the macro text. The newline preceded by a backslash shall be replaced in
the expanded macro with a newline (but without the preceding backslash character)."
-- Gabor
Anonymous
Not applicable
I tried your method and it's still not working.
`timescale 1ns / 1ps`define Digit 20
generate\
 genvar pk_idx;\
for(pk_idx=0; pk_idx<(PK_LEN); pk_idx=pk_idx+1) begin:PACK\
assign Out[pk_idx][((PK_WIDTH)-1):0]=In[((PK_WIDTH)*pk_idx+((PK_WIDTH)-1)):((PK_WIDTH)*pk_idx)];\
end \
 endgenerate
And the error is
line 5 expecting 'EOF', found 'genvar'
Professor
Professor
The compiler seems to be having a problem with the line extensions, hence the error is on
line 5 in the middle of the `define and not lower down where the macro is called.
Check to make sure there are no trailing spaces after the backslash at the end of each line
in the macro definition.  The "\" character needs to be the last character in the line.  Otherwise
the character after the backslash (space or tab) is treated as the escaped character rather
than the newline.  It's O.K. to have spaces between the end of the text in the line and the
backslash character.
i.e. - using underscores to represent spaces:
generate___\
is O.K.
generate_\_
is not O.K.
-- Gabor
-- Gabor
Anonymous
Not applicable
The redeclaration error is still there. It seems once a 'genvar' is defined, we cannot define it again in another generate. I wonder if there is a way to release the genvar variable after one generate is over?
Professor
Professor
I would have thought that this is a bug, given that the genvar scope should be local to each generate loop.
A workaround would be to take the genvar definition out of the macro and place it once before the macro
is called like:
wire [3:0] A[20:0];
wire [3:0] G[20:0];
genvar pk_idx;
Two generate loops may use the same genvar as long as the loops are not nested.
HTH,
Gabor
-- Gabor
Good one Gabor. For what it's worth, the code compiles for me.
David
"You don't scare me, Bob."
