Implementation of Alexnet CNN model using AccDNN tool and Vivado 2015.3 in Zynq xc7z020clg484-1 fpga
Hi, I want to implement Alexnet CNN model in xc7z020clg484-1 evaluation board using the tool AccDNN which is at the link https://github.com/IBM/AccDNN/tree/master .This tool will convert the alexnet cnn model file and alexnet weights file in Caffe framework to verilog modules and it also geneartes ips.tcl script for creating block rams for storing input,weights,bias values.I have attched the verilog modules and ips.tcl script as a zip file.
When running the ips.tcl script in Vivado 2015.3,IP_FLOW 19-3478 validation failed for parameter coe file error occurs. I have attched also attched the screenshot of the error. I have no idea about this error.Please help me
