Impossible to create a VHDL design flow ISE 4.2
I start a project with a XC4000 series FPGA and so I have to work with ISE 4.2, the last version available for this FPGA. I installed the software and services packs files related.
My problem is when i want to create a new project, I can't choose XST VHDL as my design flow, i just have EDIF as you can see on the following picture.
I also tried to download the previous version, 4.1. I can select a XST VHDL design flow but this time I can't select the XC4000 FPGA.
I think the problem comes from a bad installation of services packs files but I don't understand why.
Thanks and regards,
Antoine
I have the same issue.
Did you find a solution ?
Thank you
Mauro
