Impossible to view Windows in my ISE 10.1
Hi all,
I have just installed Xilinx ISE 10.1, i did a small application and when i tried to view the different windows i filed like you can see in the picture where i opened "vhd" and "design summary" files
I choose the option "float" in the menu "window", and i succed viewing the windows finally but i hope there is another solution, because it doesnt resolve my problem with other windows.
Thanks a lot
Re: Impossible to view Windows in my ISE 10.1
Thank you very much for your help, i uninstalled vista theme, and every thing is ok
I'm glad to hear it is fixed.
I've only used the Windows Classic theme under XP - so I haven't seen this issue personally.
bt
