In Ubuntu, how to open the already installed Vivado or SDK
In Ubuntu, how to open the already installed Vivado or SDK?
check these links
http://www.xilinx.com/Attachment/Install_Vivado_2014.3_on_Ubuntu_14.04.pdf
http://elinux.org/Xilinx_2013.2_software_on_Ubuntu_with_Unity_Menus_install_guide
https://youtu.be/hvD4j9x4rBM
Thanks and Regards
Balkrishan
Hi @xilinx-zhaosheng
You can invoke Vivado or SDK after setting the environment by running settings64.sh or settings64.csh depends on your shell.
In a terminal, run the following commands to set the environment and invoke Vivado:
source <vivado_installed_directory>/settings64.sh
vivado
for SDK
source <SDK_installed_directory>/settings64.sh
xsdk
Vinay
