Incorrect Schematic Hierarchy
I have a top level schematic with other schematics correctly listed underneith it. However, one of my schematics refuses to list itself under my top level, choosing instead to list itself under the FPGA just above my top level:
xc3s700an
---Bad_Schematic.sch
------D5_32.sch
---Top_Level.sch
------Happly_Schematic.sch
------D5_32.sch
I have looked at the .sch and .sym files and can't see anything wrong. I even recreated the project and added each file, same problem. Upgraded to 11.4, same.
Any ideas?
Re: Incorrect Schematic Hierarchy
Solved it!
The symbol type had somehow got changed to GRAPHIC by project navigator, very frustrating.
Solved it!
It has happeend again, but this time the symbol type hasn't been changed.
It seems to happen after I edit a symbol to add pins I didn't realise I'd need when I created the symbol. I update the level above with the new symbol and it pops out of the design hierarchy.
Historian
Historian
This is the Universe telling you that it's time to dump schematic entry and use an HDL :)
I would, but there are at least two problems with that:
1) Me, I'd have to learn it! And there would be no-one else to help check the design
2) VAB issues, it's a lot easier to get schematics validated than 'software'
Historian
Historian
true enough, but the sooner you start, the sooner you'll be good at it!
That's not true at all -- validating HDL is a heckuva lot easier than doing same with schematics. That's what testbenches and verification are all about.
With issue 2, due to the cost associated with VAB acceptance of 'software', schematics are far preferable. Validation that it works isn't the problem, it's the numbnuts verifying/validating it for use on vehicles (external body, VAB)....
Historian
Historian
Well, I don't know what "VAB" is, but from your description it sounds like a bunch of bureaucratic idiocy.
Simply put: verifying a design's correctness is a LOT easier with an HDL. Do these numbnuts really scrutinize pages of schematic code? That's ludicrous.
Vehicle Acceptance Body, it is a load of......
How closely they actually scrutinize code is unknown to me, but they charge a fortune for it. I recall they wanted to charge quite a few £K just to change one line of pascal code. I can see the point of it in general, lives are at stake, but it is a bit over the top. It's a railway environment too, so it's even worse, the strictness seems to be proportionate to the number of lives at risk per vehicle.
Newbie greg.smith
