Inout write_edif bug in vivado 2015.4?
I'm using vivado 2015.4 in Ubuntu 14.04 x64. I'm regenerating the BD from an OOC elaboration schematic, to modify it. write_edif will correctly create an inout port in netlist and component sections in its .edn file, when facing an RTL_TRISTATE component. However, it seems, it doesn't recognize if one of the RTL's pins are lifted (see attached screenshot).
(cell bus_int (celltype GENERIC)
    (view bus_int (viewtype NETLIST)
         (interface.
             (port SFPP0_ModAbs (direction INPUT))
             (port SFPP0_RS0 (direction INOUT))
(cell x300_core (celltype GENERIC)
    (view x300_core (viewtype NETLIST)
        (interface.
            (port LMK_Holdover (direction INPUT))
When generating the IP from it and importing it to a BD, external port is left as IO, when it should be an OUTPUT. Subsequent connections are disabled in BD due to wrong port configuration.
BR,
Nikos
Re: Inout write_edif bug in vivado 2015.4?
Suggested workaround:
Fix relative pins in .edn file from INOUT to OUTPUT in bus_int and component sections. Generate IP, import to BD and upgrade existing IP.
HTH
Nikos
HTH
Nikos
