Participant hycheah
Instantiating RAMB16_S36 (Where is it located?)
I inherited a design which uses ISE and I need to make modifications to it.
However, one of the files called RAMB16_S36 is missing! It is a generated file, not a hand-coded one.
Question is, how do I instantiate/produce the RAMB16_S36 file?
I tried looking around at the core generator but I don't think it is produced from the generator.
hycheah
Re: Instantiating RAMB16_S36 (Where is it located?)
compxlib
Start -> Programs -> Xilinx ISE Design Suite 11 -> ISE -> Accessories -> Simulation Library Compilation Wizard.
also useful: Software Manuals -> Synthesis & Simulation Guide (sim.pdf)
bt
You shouldn't have an HDL file for the RAMB16_S36... It is a primitive in many of the FPGA architectures (e.g. Spartan-3E).
Most likely they are directly instantiating this BlockRAM and you are confused as to why you can't find the file. It will be a black box in the synthesized netlist and reconciled in ngdbuild/map.
See the respective Library Guide for an example of its instantiation, e.g. Start -> Programs -> Xilinx ISE Design Suite 11 -> ISE -> Documentation -> Software manuals -> Spartan-3E Libraries Guide for HDL Designs.
There are multiple ways to use BlockRAM (instantiation, inferrence, Core Generator, etc.
The device user guide may also be useful. As are these:
http://www.xilinx.com/support/documentation/white_papers/wp335.pdf (Creative Uses of Block RAM)
http://www.xilinx.com/support/documentation/application_notes/xapp463.pdf (Using Block RAM in Spartan-3 Generation FPGAs)
bt
Participant hycheah
Thanks, that was helpful.
I managed to synthesize the design, but somehow simulation failed.
The error screamed,
Failed to access library 'xilinxcorelib_ver' at "xilinxcorelib_ver".
Failed to access library 'unimacro_ver' at "unimacro_ver".
Failed to access library 'unisims_ver' at "unisims_ver".
I tried to map the libraries but I couldn't find the required libraries at the Modeltech library. Mapping to C:\Xilinx\11.1\ISE\verilog\src\xilinxcorelib_ver doesn't work either.
Am I missing something? BTW, I am using the Webpack 11.4 and Modelsim PE Student Edition 6.5d.
compxlib
bt
Participant hycheah
Finally managed to get the libraries compiled and mapped to modelsim.
However, I found out that I have to map the libraries all over again when simulating a new project.
Is there a global modelsim.ini where I can map the libraries only once?
hycheah
Participant hycheah
Found it. Located at C:\Modeltech_pe_edu_6.5d\modelsim.ini
Thanks Tim
