tahirsengine1
Instantiating block diagram in HDL top
Hey guys,
I received a design project. There is a VHDL top file and there is a block diagram in that project.
The block diagram is instantiated in VHDL.
I had to change block diagram. And now I need to update its instance in VHDL.
The block diagram name is glue.bd
When I use the option "View Instantiation Template", it shows me a file with the module name "glue_wrapper" . But in actual design it is instantiated like
glue_u0 : entity glue
port_map(
So how will I update the instance in VHDL file? I can simply add the additional ports in instance, but I really want to do it the proper way.
syedz
@tahirsengine1
Remove the existing wrapper file from the project and make the modification to block design. After BD validation right-click on .bd file under sources windows and select create HDL wrapper.
Check topic "Integrating the Block Design into a Top-Level Design" at page 108 in below user guide:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug994-vivado-ip-subsystems.pdf#page=108
--Syed
