Advisor
Advisor
Invisible IP Mystery
I am having a lot of trouble adding IP cores to my project in a way that synthesis will see it.
In my TCL script that sets up the project I have these commands.
read_ip ../ip/fr_rom_3/fr_rom_3.xci
read_ip ../ip/fr_rom_2/fr_rom_2.xci
generate_target {all} [get_ips *]
Unfortunately, when I run synthesis it tells me
ERROR: [Synth 8-493] no such design unit 'fr_rom_3'
This is confusing because "report_ip" and "get_ips" both show the cores to be in the project.  Also, if I open the project file in the Vivado GUI it shows the cores correctly located under the vhdl source that calls them.  When I try to run synthesis inside the GUI it instantly replaces the core icons with red question marks and gives the same error message above.
Using the GUI, I have found if I remove and then add the xci files a couple of times Vivado will recognize the cores and synthesis can proceed.
I have compiled from scripts many times before with IP cores so I don't know why this suddenly stopped working.
Any ideas?
  Pete
DSP in hardware and software
Re: Invisible IP Mystery
You need to launch IP OOC synthesis run after generating output products of IP.
synth_ip [get_ips ip_name]
You can use above command to do this.
Refer to page-155 of http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug896-vivado-ip.pdf for more details.
Deepika
Deepika.
Advisor
Advisor
I should add that the generate_target command is generating a bunch of files like I expected.
I also verified that I am calling the core correctly by looking in the generated .vho file. All the formal parameter have the right names and sizes.
Hello @pedro_uno ,
When you say ip's are getting red question marks i feel cores are generated for some other fpga device and you are trying to use these cores for other fpga family.
is this behaviour consistent? if yes can you attach your script and .xci files to reproduce the issue?
-Pratham
Advisor
Advisor
Pratham,
Thanks for taking a look at my problem. That was a good idea about wrong families. I double checked the device settings in the IP versus the compilation project and they appear to be the same exact part.
I have created a mini-design that shows the problem.  It is attached to this reply.
To reproduce the problem just go into the implement folder and run
source setup.tcl
source compile.tcl
That should give the error.
Deepika
Deepika.
Advisor
Advisor
Deepika,
That worked.
I added this command to my compile script, first thing after opening the project.
synth_ip [get_ips *]
It identifies when the IP is already synthesized and does not blindly rerun synthesis on the IP each time I compile.
This left me wondering how all my other FPGA projects were able to compile.  It looks like some types of IP cores, FIR filters for example, do not need synthesis.  On the other hand, memory IPs need to be individually synthesized.
I normally infer or instantiate memories so they can be parameterizable. I guess that is why I never ran into this before.
Thanks for the help.
  Pete
