Is is allow to have spaces in path names in windows?
I use Vivado as programming software to program Basys 3. But my university lectuerer said, that i cannot use spaces instead use _ to replace spaces, but i didn't because it will become a hassle to reorganize a whole file system...
Re: Is is allow to have spaces in path names in windows?
In 2020, whitespaces in file paths really shouldnt matter - but they still cause problems.
https://forums.xilinx.com/t5/Simulation-and-Verification/ERROR-Simulator-45-7-No-such-file-C-Users-kirscwm1-Documents-My/td-p/832977
Use _ instead of space.
Hi @zaahm18
Yes this is mentioned in UG973:
If you do not follow this you might face unpredictible bahaviour.
You do not have to re-organize the full file system. Just work at the root of your driver and if you need just map a new drive at a specified directory.
Florent
@zaahm18,
I have the same opinion as @richardhead
It is just a bad practice (and many seasoned engineers would tell you the same).
FPGA enthusiast!
All PMs will be ignored
