Participant saurabhsk
Issue while running Coregen in batch mode
 I generated DDR3 model for virtex-6 in verilog. I would like to give a try with batch mode for VHDl now. So I took the mig33.xco file  , which looks like :
# BEGIN Project Options
SET addpads = False
SET asysymbol = True
SET busformat = BusFormatParenNotRipped
SET createndf = False
SET designentry = Verilog
SET device = xc6vcx75t
SET devicefamily = virtex6
SET flowvendor = Synplicity
SET formalverification = False
SET foundationsym = False
SET implementationfiletype = Ngc
SET package = ff484
SET removerpms = False
SET simulationfiles = Behavioral
SET speedgrade = -2
SET verilogsim = True
SET vhdlsim = False
# END Project Options
# BEGIN Select
SELECT MIG family Xilinx,_Inc. 3.3
# END Select
# BEGIN Parameters
CSET component_name=mig_33
CSET xml_input_file=/home/mine/ddr3_xcv6_verilog_trial/mig_33/user_design/mig.prj
# END Parameters
GENERATE
# CRC: 511ce836
 As i just want it from verilog to vhdl , so i made this change and run the command:
/in/pnrtools/ise_11.4_l68/ixl/ISE/bin/lin/coregen -b mig_33.xco -r -d
But it is giving error :
WARNING:sim:436 - The selected IP (MIG,3.3) is incompatible with the currently
   selected part.
WARNING:encore:182 - Invalid project options. Family not set.
WARNING:encore:181 - Invalid project options. Device not set.
WARNING:encore:183 - Invalid project options. Package not set.
WARNING:encore:184 - Invalid project options. Speed grade not set.
WARNING:encore:175 - Project options (family='', device='', package='', speed
   grade='') are inconsistent, unavailable or incorrectly entered.
Am i missing anything ???
Thanks in advance.
-Saurabh
Re: Issue while running Coregen in batch mode
You didn't miss anything. Actually the problem is most likely that you have one too many command line option for coregen. Try removing the -r from the command (see below) as it can't be used with the MIG core.
coregen -b mig_33.xco -d
Cheers,
Jim
