schlee68
JESD204_Hardware_Demo
During Generating the Hardware Demo
Stoped In following screen
What is the problem?
I have received in Xilinx web site, following included file
thakurr
Hi @schlee68
Can you make sure jesd204_0_clocking.v is present in the project directory location?
Rohit
Rohit
balkris
This files should be there in the location
..\JESD204_Hardware_Demo\ac701_hwdemo\jesd204_0_example\jesd204_0_example.srcs\sources_1\imports\example_design\support
Thanks and Regards
Balkrishan
sschne03
I had the same problem when I was running this demo while using Vivado 2018.1.  Because I downloaded the demo for 2015.2 I switched to a remote machine running Vivado 2015.2 and was able to generate the bitstream.  I then copied the bitstream and the debug_nets.LTX file back to my local machine and it appeared to work mostly well, although I am new to the VIO GUI so I can't say that definitively.
