Kintex-7 parameterized macros, unimacros and design elements design entry
I was reading throught the FPGA libraries.
I notice there are 3 groups of cells, parameterized macros, unimacros and design elements (primitives).
Q1. If I want to use the 3 groups of cells, do I just need to instantiate them in the verilog code?
Q2. Design elements(primitives) are simply the basic elements. What is the differences between parameterized macros and unimacros?
Thanks!
Re: Kintex-7 parameterized macros, unimacros and design elements design entry
Hi chao_xilinx,
1. A Design Element is suppose to be the Actual Primitive synthesis will use. It's what your HDL code will be transformed to from synthesis. So if you want to make a memory, you would find a FIFO, a BRAM, and URAM primitive defined with all it's ports. It's upto the user to know how to connect them up.
2. A Unsim Macro is suppose to make this a little easier and more flexible. Instead of a specific RAM primitive, you can choose the functionality, and then via parameters customize it. More like setting up an IP. So the same code might remain more readable, easier to change, and easier to share between devices, but still give you the control over trying to infer the primitives in HDL.
3. The XPM is a more robust version of item 2. You get more control over the Primitive from a single XPM definition. It also is intended to be more similar to having used an IP, and I believe for Ultrascale, you have to use XPMs over their UNIMACRO variants. So XPMs are really the successor.
Hi chao_xilinx,
