tester11
Locked IP and untable to select for upgrade
I changed my board type and run upgrade_ip [get_ips *] and still got 2 modules that can't be changed/selected in the gui for upgrading
arpansur
Hi @tester11,
Can you please check the IP paths and add the IP definition to the project?
Arpan
arpansur
Hi @tester11,
Arpan
hemangd
Hi @tester11,
You need to figure out where the ip was stored and if its repository back to the list of ip reposistory. Go to project settings , IP repositories and check if the ip location is there and if not then add it.
hemangd
hemangd
tester11
