chandan_e
Logic 0 and 1 in Vivado IPI
How can I connect an input pin of an instantiated IP ot logic0 or logic1 in IP integrator? Doesn't seem very intuitive or obvious.
Chandan
yenigal
Have a look at the below post
http://forums.xilinx.com/t5/Vivado-TCL-Community/Connecting-signals-to-ground-in-Vivado-block-design/td-p/345507
Satish
yenigal
Satish
chandan_e
Hi Satish,
The "constant block" solution in the link you pointed me to works perfectly. Thanks!
Chandan
