MIPI CSI-2 Receiver for ISE/Xilinx core generator
Greetings,
I have been looking for a MIPI CSI-2 Receiver and I found it for Vivado Design Tool. My Board is a ML405 (Virtex 4) and it need to be programmed with ISE. Does someone know if exist this IP Core for ISE or Xilinx Core Generator?
Thanks!
Andres Aleman
Re: MIPI CSI-2 Receiver for ISE/Xilinx core generator
Hi @andres.aleman,
I am afraid the answer is no. It is not available for Virtex-4.
Refer this page for supported devices:
http://www.xilinx.com/products/intellectual-property/ef-di-mipi-csi-rx.html
Nupur
Hi @andres.aleman,
Nupur
Thanks!
What other tool do you recommend me to try if I do not have this ip core for Virtex-4?
Thank you.
Hi @andres.aleman,
As mentioned in the previous link, it is available for Vivado Design Suite for the following two devices:
Virtex UltraScale+Kintex UltraScale+
Nupur
