MMCME2 in a wrong clock region
I'm using Vivado 2016.1 and I have a strange problem. I used ClockingWizard to adjust the frequency of an external clock (gps_clk) and it was working nicely, on default settings, I only changed output frequency. Then I added another ClockinWizard to adjust different clock (stable_20MHz). Then I get en error: [Place 30-575] Sub-optimal placement for a clock-capable IO pin and MMCM pair. After I added set_property CLOCK_DEDICATED_ROUTE FALSE I was able to generate the design, and indeed input pin and MMCM were in different clock regions. Input in X1Y1, MMCM in X1Y0, so it is wrong. However, there is an MMCM in X1Y1 region that is not used.
So the question is: Why Vivado doesn't use it instead?
I'm doing everything on default settings, is there a way to force Vivado to use the correct one?
Re: MMCME2 in a wrong clock region
OK, I looked into it again and it was my fault. I used wrong pin as an input (not clock-capable). Error message wasn't very clear, and after setting CLOCK_DEDICATED_ROUTE FALSE it actually placed it in wrong clock region, which is still strange but fixing the first problem made this one disappear. So it was not a tool issue, it was my eyes issue. Thank you for your answer I'm marking this as solved.
Hi @mkarwat
Are you saying that there is an unused MMCM location in clock region X1Y1 and tool is failing to use it?
You can try locking the MMCM instance using constraint below (remove clock_dedicated_route constraint)
set_property LOC MMCM_site_name [get_cells MMCM_cell_name]
If this works then this is tool issue, please upload _opt.dcp file here.
Deepika.
