Markings on top and bottom of XC3042-50PG84M
Hello, I have a military grade XC3042-50PG84M. On the top is the part number and X07454M and X9222ME. On the bottom the markings are S2776W and A5959. Can someone please tell me what the date code is and what the other markings indicate in detail? I have searched for a document explains this but have found none. Thank you
Re: Markings on top and bottom of XC3042-50PG84M
HI @xilinxinformation
Check this AR.
http://www.xilinx.com/support/answers/1067.html
Thanks,Vijay
check this datasheet for all the above details
http://pdf.datasheetcatalog.com/datasheets/1150/287701_DS.pdf
Thanks and Regards
Balkrishan
This is obsolete version and no details available
you can install the supported classic version of ISe and see if you can find old documentation
http://www.xilinx.com/tools/classics.htm
Thanks and Regards
Balkrishan
You should get the lot code/date details from the shipment of these devices from your authorized distributors.
You can talk to the FAE/Sales person from your distributor of this device
I do not know where it was purchased so cant use distributor.
Thanks but no help. I guess Xilinx can't afford actual tech support or provide a tech support number?
Tried it but no help.
Thanks but no help.
Observer trapygin
I also have this problem, please help me
