Observer hkassir72
Minimal AXI Interface with Burst Support
I want to instantiate an AXI slave that supports burst reads/writes.
What is the minimal list of ports I must have in order to connect my block to an AXI master through an AXI Interconnect. I know that the user ports can be dropped. But can I also drop ID, Lock, Cache, Protection, Region, and QoS ports?
And what do the attributes (HAS_CACHE, HAS_LOCK, HAS_PROT, HAS_QOS, HAS_REGION) indicate exactly? From my understanding, they mean that I must declare the ports, but the attribute indicates that the Master doesn't have to drive the signals (which kind of answers the first question but I would like to verify).
Observer hkassir72
Re: Minimal AXI Interface with Burst Support
I tested a system with MPSOC Zynq Ultrascale+ ARM processed as a master. It seems that the only necessary full AXI port to support bursts is the ID (aside from burst length and size, of course).
I could safely synthsize and run an AXI bus without Lock, Cache, Protection, Region, and QoS ports.
Observer hkassir72
