Missing folder " .Xil " in vivado project
In the Project directory, their is a folder call .Xil, what is function of this folder?
I got this error from Vivado :
  • [Common 17-37] Directory in which file design2_propImpl.xdc is to be written does not exist [c:/tomc/development2/laser/.Xil]
I noticed some of my project also have this folder but when I check the lase/.Xil folder which Vivado complains about, it is not there.
Re: Missing folder " .Xil " in vivado project
Hi @tchin123,
Did you try the steps which i mentioned in my last thread?
Let me know if you have further queries on it, else you can close the thread by marking it as accepted solution.
hemangd
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
Hi @tchin123,
The .Xil directory is a temporary bookkeeping directory used by the tool to lower memory usage during runtime.
As mentioned in the below AR:
https://www.xilinx.com/support/answers/55514.html
Thanks & Regards,
Sravanthi B
Thanks & Regards,
Sravanthi B
It is not in my project directory.
AR#55514 mentioned that this is critical as part of Vivado implementation.
Why is this folder missing,
Should I create and put it there
Hi @tchin123,
Close all your projects of Vivado. Open a new Vivado GUI session - go to tools - Settings - Project - Change option of Default Project Directory to "Specify project directory" where you can add your desired directory path where you want to store your project files -then apply it. (as hown below.)
And then create your project and check that you face the same issue or not.
hemangd
hemangd
Hi @tchin123,
hemangd
hemangd
For the record, I had a similar issue running on Linux and solved it by removing the ~/.Xilinx folder. No idea was that happens though.
