dje666
Voyager
Voyager
Missing utility Differential I/O Buffer in Vivado 2016.4
Dear Colleagues,
I am following a quick-take video that builds up the PCIe Root complex design, and one of the final tasks is to add a utility differential I/O buffer to the block-design to bring the ref_clock into the system. However, in Vivado 16.4 I can only find a utility-buffer component to add, not the utility-differential I/O buffer.
Is the utility-buffer to be setup to act as the differential buffer, or is the differential buffer component missing from 16.4?
TTFN.
DJE
muzaffer
@dje666 utility buffer can be configured as a differential one so it should do what you want.
muzaffer
